Campus Switching and Routing
Three 3810M Mesh,Ring, VSF, redudancy advice
I have 3 aruba 3810Ms and I want to create redudancy. So just in case one goes down, my network would still be up.
What type of configuration would you reconmend I use?
I have one 3810 at City Hall, and 3810M at 2 different intersections in the city.
Re: Three 3810M Mesh,Ring, VSF, redudancy advice
Hi Brian,
We don't support VSF on the 3810M and from the sound of your scenario.
What type of redundancy are you looking for? L2 and L3 or just L2 or L3?
Justin
