Campus Switching and Routing
Occasional Contributor I
Traffic Shaping on 2930F
Hi All,
Is traffic shaping supported on 2930F ?
Re: Traffic Shaping on 2930F
Not sure on your exact configuration but traffic shaping is possible. Have a look at Traffic Management configuration guide with QoS or Calssifier based policies.
ok, it was just to know if the feature is supported to be compliant with the needs of my customer
Regards
No problem more than happy to help.
