Campus Switching and Routing
Two 5400R VSF and Distributed Trunking
Hi all,
I have a question regarding VSF and distributed trunking.
At the moment I wasn´t able to find the requested information for my problem.
We have four 5406R switches.
Two in data center 1 and the other two in data center 2.
The Access switches are now connected to each data center with one link in active-passive mode.
(the second link is blocked by spanning-tree)
Now we are thinking about creating a VSF pair for each data center.
The pivotal question is, if it is possbile and supported to create a Distributed trunking pair out of the two VSF clusters.
That would allow us to connect the Access switch with a single LACP trunk with one link at data center 1 and the second at data center 2.
regards
Daniel
Re: Two 5400R VSF and Distributed Trunking
No, see PPT extract:
VSF system
Mutually exclusive with:
- QinQ
- Distributed Trunking & meshing
- Second Management Module in each chassis
Same 5406R and 5412R models must be used
FYI, for others looking, you may also want to search the HPE support forums under networking - there is a lot of ProCurve/AOSS material there (I see Xerox has posted there too!)
https://community.hpe.com/
https://community.hpe.com/t5/ProCurve-ProVision-Based/bd-p/switching-e-series-forum/
Richard Litchfield, HPE Aruba
Network Solution Architect
Network Ambassador
Hi Richard,
thanks a lot for the explanation.
