Campus Switching and Routing
Upgrade from 6.4.3.4 to 6.5.1.10 - AMON question
Hello all,
I need to upgrade an ARUBA 7210 controller from 6.4.3.4 to 6.5.1.10. I see in the release notes this note :
When upgrading from an existing ArubaOS 6.4.x release, it is required to set AMON packet size manually to a desired value. However, the packet size is increased to 32K by default for fresh installations of ArubaOS 6.4.3.9.
So I've make research and I find this :
https://community.arubanetworks.com/t5/tkb/articleprintpage/tkb-id/ControllerBasedWLANs/article-id/2289
So I've got two questions :
  • I understand I need to size manually the packet size for AMON, I need to do this before or after the upgrade ?
  • The note explain the packet size is 32k. The new size (in bytes) is 32768 ? Or 32000 ?
Thanks for your help !
Regards
Re: Upgrade from 6.4.3.4 to 6.5.1.10 - AMON question
Sorry my post is not in the right place...
Is it possible to close this post ?
