Campus Switching and Routing
Contributor I
VRRP Redundancy Master unreachable?
Dear All,
I was working on VRRP Redundancy wit two mobility controller 7210 and it's work fine,When I disconnect the master the backup run very well and all Aps Up,But when returning the master back the Backup controller lost connection and says "master unreachable" and when i run this command on two controller
"(config) vrrp222
(config-vrrp) no shutdown
the connection back again .
Kindly any help to make the all process automatically
