Campus Switching and Routing
VSF Stacking on 2930f
Can i do VSF stacking between a 2930F of 24P POE with a 2930F of 48P Poe???
Cheers
Carlos
Alternetworks Corp
Contributor I
Re: VSF Stacking on 2930f
Yes, you can make a VSF stack using different 2930f models.
http://h20566.www2.hpe.com/hpsc/doc/public/display?docId=c05365316 page 605
The VSF feature allows the user to form a stack of up to four devices of any SKU, including mixing the SKUs in a single stack. The switches in these stacks are interconnected using standard Ethernet connections. These interconnections between member switches are called VSF links.
If it helps please add Kudos
Yes, you can stack up to 4 units with any model of the family of 2930F
It-is possible to setup a stacking with four 2930 F with Copper 1 Gb and fiber 10 Gb like this ? Two 2930F interconnected with two Copper 1 Gb in a room . Two other  2930F interconnected with two Copper 1 Gb in a second room and the two rooms interconnected with fibre 10 Gb.
                    (one OM4 10 G)
2930F --------------------------------2930F
  I |                                                | |
  I |  (two  Copper 1 gb)                 | |  ( two  Copper 1 gb)
                 (one   OM4 10 Gb)
Thanks a lot,
Hervé
Contributor I
Hi, sadly, no ... but its a good idea!
At least you can do link aggregation between the rooms.
Look at page 653 from here
VSF restrictions
• VSF is mutually exclusive with distributed trunking, mesh, and Q-in-Q.
• VSF port restrictions:
    ◦ Must be 10Gbps/1Gbps.
    ◦ A VSF link can only comprise ports with the same speed; either all 10G or all 1G. A VSF port’s speed which does not match with the global port speed, will be in a down state. The command show vsf link detail will display an error message.
    ◦ Maximum eight ports can be configured on one VSF link.
    ◦ VSF ports must be directly connected and there should be no transit devices between members.
• In a VSF virtual chassis, flow-control is not supported between ports on different chassis across VSF links.
• A VSF stack downgrade is not allowed if we try to downgrade a 2930 VSF stack to a 16.02 image.
Ok..
Or i replace  copper by fiber and it s ok but i have note fiber port availbale.
And if i do link aggregation between the rooms, i have two VSF stacking, one  VSF in each room. It is possible to do VRRP between these VSF ?
Thanks a lot,
Hervé
Contributor I
Yes, VRRP is supported.
Routing Manual page 241
ok thanks a lot.
Occasional Contributor I
hi sorry, does this mean that 1Gbps or 10Gbps is supported for VSF stack for 2930F series?
1Gbps is workable? I am looking into 2 units of 2930F 24G SFP to perform VSF stack.
Please advice, thank you
Contributor I
Yes, you can configure VSF using 1G links over 2930F.
