Campus Switching and Routing
VSF ring topology on 2930F stack
I'm trying to configure a 3 switch ring topology on a 2930F stack but only the first two switches join.  I've been reading up on the documentation but I only see examples for 2 and 4 node VSF stacks.  One thing I've run into is the Link numbering.  For example, if I connect Link1 to Link1 on top and middle switch, then Link 2 to Link 2 between the middle and bottom switch, then Link 1 can only be used on the bottom switch (up to the top switch to complete the ring) but Link 1 is already used on the top switch?
Re: VSF ring topology on 2930F stack
what's odd, is even if I rule out the ring topology, the 3rd switch isn't coming online in the chain topology so something else is going on.  The 3rd switch is a 2930F but is the only POE switch in the stack... but I've read you can mix and max.  Firmware is all the same.
What revision of ArubaOS-Swtich firmware are you utilizing?
ROB HAVILAND
DIRECTOR TME, ARUBA WIRED INTELLIGENT EDGE
M: 414.841.3605 | rob.a.haviland@hpe.com
8000 FOOTHILLS BLVD | ROSEVILLE, CA 95747 USA
WC.16.05.0007
factory defaulting the 3rd switch allowed it to join the VSF stack, however I'm unable to get the ring topology to work.  Working through that now....
Just a quick update.  The ring did eventually connect up but required me to unplug the DAC cables and plug them back in - then the ring topology formed instead of the chain.
Also, I was mistaken on the VSF port links.  They do not need to be linked to the same port on the other switch as this is impossible to do on a 3 switch ring topology.  For example, Link 1 on the top switch is plugged into Link 2 on the bottom switch.
Greetings!
When you were forming the VSF stack, were you allowing the switches to automatically join the VSF domain by connecting them to the commander/standby, or were you manually provisioning each member in advance?
Matthew Fern | Technical Marketing Engineer, Wired Intelligent Edge
Aruba, a Hewlett Packard Enterprise Company
