Campus Switching and Routing
Virtual Stacking 2530 switches
Good afternoon! I want to know, how can stack (Virtual Stacking) 16 switches of the series 2530. In the product bulletin says the following.
Regular Contributor I
Re: Virtual Stacking 2530 switches
Here you can found the info about virtual stacking.
http://www.hp.com/rnd/device_help/help/hpwnd/webhelp/HPJ4813A/configuration_stacking.htm
I don't think that the 'real'stacking is going to be coming to the 2530 series. With real stacking i mean the stacking like IRF of VSF.
Cheers
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
Here's also the latest from the Advanced Traffic Management guide for the Aruba 2530 similar to the doc posted above (Virtual Stacking starts on pg 241):
http://h20566.www2.hpe.com/hpsc/doc/public/display?sp4ts.oid=5333803&docLocale=en_US&docId=emr_na-c04943200
As mrzero stated, it is not like backplane stacking on the Aruba 3810 or Virtual Switching Framework (VSF) on the Aruba 5400R modular switch.
Excelent!!
Excelent!!
