Campus Switching and Routing
Occasional Contributor I
When will Mobility Access Switches be supported by Aruba Central?
Can Aruba Networks provide an official roadmap for Aruba Central support for the S3500/S2500 MAS products?
Thank you!  Regards
Jamie
Aruba
Re: When will Mobility Access Switches be supported by Aruba Central?
Jamie,
We like to refrain from talking about roadmap items on the forums. I recommend reaching out to your partner and/or Aruba SE and they can give you updates on roadmap plans assuming there is an NDA in place.
Best regards,
Madani
Super Contributor I
Nothing on this but heard controller will be next on Central, do check with local SE.
Normal Guy
