Campus Switching and Routing
Occasional Contributor I
Where can I find the key for Aruba Activate in a M3810
Can somebody tell me, where I can find the key in a M3810 to activate them in Aruba Activate.
Thanks for your Help
Re: Where can I find the key for Aruba Activate in a M3810
The command "show activate provision" should return the key.
Hope this helps.
Justin
Hi Justin,
thanks for your answer, command works, but I got back
Activate Key: not available
Running Aruba OS 16.02.10
Any other ideas?
BR
Frank
A couple of things to check:
  • Make sure you're not behind a proxy
  • Check that the switch has the correct time
Can you paste the log output to see if it's returning any kind of return message?
