Campus Switching and Routing
Regular Contributor I
Wired VOIP using Mobility Switches
I am curious if there is a way to similarly add QoS to wired connections. We have a VOIP Vlan as per a standard install. We do not use any Wireless VOIP technology and that seems to be what all the guides are based around.
We have Mobility Switch 2500's that are the backbone of our network and a 7210 Controller. We just want to make sure call quality is something we take care of above internet traffic.
Switches are running 7.3.1 software
Controller is running 6.4.0.3 software
Re: Wired VOIP using Mobility Switches
Did you look at the VoIP MAS VRD?
Tim Cappalli | Aruba Security
Aruba
Have a look at the Voice over IP Deployment with MAS VRD: http://www.arubanetworks.com/vrd/VoIPwMASAppNote/wwhelp/wwhimpl/js/html/wwhelp.htm
AMFX | ACCX | ACDX | ACMX
Aruba
.....like Tim said.....  :smileysurprised:
I did not see the VRD for it. I suppose because I was looking for Mobility Switch. I forget that their full name is Mobility Access Switch. Thank you for pointing me in the right direction as always!
