Campus Switching and Routing
Occasional Contributor I
X509 certificate generation on 2930F
Hi all,
Is it possible to generate a X509 certificate (with a validate duration) on 2930F for HTTPs access mode ?
Re: X509 certificate generation on 2930F
Yes, you can. Check the ArubaOS-Switch Security Access Guide for the 2930F/WC version 16.04 that is available from the HPE Networking Information Library page 363 on Generating the switch's server host certificate.
After you did, use the web-management ssl command to activate SSL.
Thank you for the answer !!! Rgds,
