Campus Switching and Routing
Occasional Contributor I
Zero Touch Provisioning, image problems
We are trying to get zero touch provisioning to work for our 2930F switches. We don't want to use airwave or activate/central.
Everything works fine and the switch get the correct configuration but I can't get the switch to download a new image firmware.
I can't find any documentation how to configure image upgrade.
This is my isc-dhcp configuration (read somewhere that Cisco switches ueses option 125 for image upgrade, doesn't work...):
option configfile code 67 = text;
option tftpserver code 66 = text;
option imagefile code 125 = text;
subnet 10.202.0.0 netmask 255.255.255.0 {
    range 10.202.0.10 10.202.0.200;
    option routers 10.202.0.1;
    option subnet-mask 255.255.255.0;
    host accesswitch {
        hardware ethernet e0:07:1b:34:0c:a0;
        fixed-address 10.202.0.5;
        option tftpserver "172.18.20.51";
        option configfile "CN68FP53DN.cfg";
        option imagefile YA_16_04_0011.swi;
In my TFTP server I can't see any requests for the image file.
Thanks!
Re: Zero Touch Provisioning, image problems
Zero touch provisioning only works with Airwave or Central.
http://h22208.www2.hpe.com/eginfolib/networking/docs/switches/K-KA-KB/16-01/5200-0137_MCG/content/ch11s07.html
Well it is working with ZTP-configuration with only DHCP and TFTP server.
Why would you have this command in place if it's only working with airwave?
NS-0001# show dhcp client image-file-update
Downloading Image File from TFTP server is enabled
Log also shows the following:
I 01/01/90 00:02:30 00092 dhcp: ST1-CMDR: Enabling Auto Image Config Download via DHCP and turning off auto-tftp if enabled
Are you saying that DHCP/TFTP is viable only for configuration of device but if I want to upgrade, I need to use airwave?
Thanks!
Let's take a step back.
Do you want to upgrade your firmware and distribute configuration via TFTP?
Zero-Touch is the brand name for a specific process that requires Airwave or Central.
Yes I want to upgrade firmware and distribute configuration using only DHCP options and TFTP.
Sorry if I confused you with the ZTP acronym.
Good morning, I was just taking a look at this thread and noticed that you stated that you are using a 2930F but for some reason it looks as if you are tying to load incorrect firmware “YA_16_04_0011.swi”.
Can you try it with the “WC_16_04_0011.swi” and see if you still get the same results? depending on the switch model number, even though the “16_xx_xxxx.swi” looks the same, each model will start with a different identifier “ya, wc, wb, kB, k, etc”.
Benny
Benny
Actually I was doing this with a 2530 for LAB, sorry for the confusion. In production we use 2930F.
Hello, found the solution. The DHCP sub-option 145 needs to be encapsulated inside DHCP option 43. Sub-option 144 can also be used to specify configuration file.
Here is the DHCP configuration file:
option space NEW_OP;
    option NEW_OP.image-file-name code 145 = text;
    option NEW_OP-encapsulation code 43 = encapsulate NEW_OP;
subclass "vendor-class" "HP J9774A 2530-8G-PoEP Switch                            dslforum.org" {
      option vendor-class-identifier "HP J9774A 2530-8G-PoEP Switchdslforum.org";
    option NEW_OP.image-file-name "YA_16_04_0011.swi";
