Campus Switching and Routing
frc
aruba 2930F Layer3 operation mode
Hello All, I have some questions regarding Aruba 2930F layer 3 operation and features, and appriciate any help.
1 - Does the ip level features are available for configuration on the webgui (routing, interfaces ip's, dhcp, etc)? If so how do I get them on GUI (for the moment only CLI)?
2 - Does this switch model supports an interface to work as I pure layer3 interface or is that only supported by creating SVI's (vlan interfaces)?
3 - Upon a DHCP pool with range/subnet is it possible to exclude some ip addresses from the pool (excluded-address ...) -- don't get that command?
4 - do you know or have a sample of a DHCP database that we could pull into the switch for operation as a DHCP server (ip addr leasings to clients) instead of defining pools and single static ip-mac binding per pool (don't find anywhere the database layout/structure to be imported and applyed by the switch)!?
best regards, and thanks in advance
