Campus Switching and Routing
Contributor I
auto lacp feature from MAS line
Did the auto lacp feature from the 7.4 MAS code line get integrated into the new aruba/hpe switch offerings?
Re: auto lacp feature from MAS line
Greentings!
Are you referring to Aruba Mobility Access Switch or ArubaOS Switch?  This would help in answering your question.
Thank You,
Priyank Patel
ArubaOS-Switch products have the following feature which is the equivilant of auto lacp:
Dynamic LACP trunk
The switch automatically negotiates trunked links between LACP-configured ports on separate devices, and offers one dynamic trunk option: LACP.
To configure the switch to initiate a dynamic LACP trunk with another device,use the interface command in the CLI to set the default LACP option to active on the ports you want to usefor the trunk. For example, the following command sets ports C1 to C4 to LACP active:
switch(config) int c1-c4 lacp active
The preceding Example: works if the ports are not already operating in a trunk. To change the LACP option onports already operating as a trunk, you must first remove them from the trunk. For example, if ports C1 to C4 are LACP-active and operating in a trunk with another device, you would do the following to change them to LACP passive:
switch(config)# no int c1-c4 lacp
Removes the ports from the trunk.
switch(config)# int c1-c4 lacp passive
Configures LACP passive
You can find additional lacp options in the ArubaOS-Switch Management and Configuration Guide:  https://support.hpe.com/hpsc/doc/public/display?docId=a00038765en_us
ROB HAVILAND
DIRECTOR TME, ARUBA WIRED INTELLIGENT EDGE
M: 414.841.3605 | rob.a.haviland@hpe.com
8000 FOOTHILLS BLVD | ROSEVILLE, CA 95747 USA
