Campus Switching and Routing
certification
Community Manager
Re: DUMPS for ACSA and ACSP certification
It is a violation to buy, use or share brain dumps and penalties include revoking of all Aruba certifications and being banned from the certification program.
Airheads Community - The best place to Connect. Engage. and Learn.
certification
Sry.. Thanks for the suggestion
Regular Contributor I
You tell them Jamie!!!
The only good substitute for learning is ........ learning. You just have to put in your effort!!
If you cheat on exams you don’t have the knowledge that come with the certification level. That will come to light if your knowledge is needed in the field during installation, configuration and troubleshooting.
So do yourself a huge favor and learn, learn, learn!
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
