Campus Switching and Routing
how do I prevent wireless users from accessing an internal network behind the controller
The wireless DHCP subnets can access the internal network via the port we are managing the controller with (this is a 7010 running OS 6.4.2.10).  The only way I've found so far is to shut that port down and manage the controller out of band (console connection)
Re: how do I prevent wireless users from accessing an internal network behind the controller
You would add firewall policies to your user roles:
http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Content/ArubaFrameStyles/Firewall_Roles/Policies.htm
Tim Cappalli | Aruba Security
