Campus Switching and Routing
Occasional Contributor I
how to see switch device-type on CLI
hi folks,
what interessts me for a long time now - is it possible to query the exact switch model on the CLI, for example Aruba 2930M 24G Switch = JL319A (= which can be seen for sure via "show running in the first line")?!
greets
Daniel
Re: how to see switch device-type on CLI
Hey,
Try "show tech buffers".
ACMP, ACCA, CWNA
Greetings!
A better, saner option would be this command (with example output):
switch# show dhcp client vendor-specific
Vendor Class Id = Aruba JL258A 2930F-8G-PoE+-2SFP+ Switch
Processing of Vendor Specific Configuration is enabled
It's a bit non-obvious, but this should get you the info you need.
Matthew Fern | Technical Marketing Engineer, Wired Intelligent Edge
Aruba, a Hewlett Packard Enterprise Company
likewise:
show lldp info local
In Addition to the above commands you can get the required information with command "show modules", This will work on all the moduler switches.
The output will be like below:
SW2# show modules
 Status and Counters - Module Information
  Chassis: 2930M-24G  JL319A         Serial Number:   XXXXXXXXXX
  Slot  Module Description                         Serial Number    Status
SW2#
