Campus Switching and Routing
i am not able to login to the controller gui when i am trying to login gui its showing captiveportal
i am not able to login to the controller gui when i am trying to login gui its showing captiveportal and its connected to a aruba switch...what is the solution..
Mallikarjun
Re: i am not able to login to the controller gui when i am trying to login gui its showing captivepo
I would SSH into the controller and type "show port status".  Make sure that the uplink interface to your network is trusted.  If by chance you created a port channel, but default that is also untrusted, so you make that trusted:
config t
interface x/x/x
trusted
