Campus Switching and Routing
ip forward-broadcast ACL
I have a HPE 5510 switch which is comware 7 based.
I need “ip forward-broadcast”. So this isn’t hard to configure but in comware 5 it was possible to add an ACL to the “ip forward-broadcast”.
Acl 3001
rule 10 permit udp source 192.168.200.0 0.0.0.255 destination 10.0.0.255 0 destination-port eq 9
Comware 5: ip forward-broadcast acl 3001
Comware 7: ip forward-broadcast
So to have less broadcast forwarded how to add a acl to the “ip forward-broadcast”
Re: ip forward-broadcast ACL
Had the exact same question this morning:
You can just apply an acl to the interface with 'packet-filter 3001 outbound' (or inbound, depending of your network config).
Your ACL may be:
Acl 3001
  rule 15 deny ip destination 10.0.0.255 0
rule 20 permit ip
Hope this can help someone avoiding loosing time…
