Campus Switching and Routing
Frequent Contributor II
ip helper-address on MAS
We have S2500 MASs at the network edge. Currently, on each VLANs routed interface at the MDF, we have configured dhcp-relay to get to two servers, 10.10.80.11 (DHCP) and 10.10.80.60 (ClearPass). This works fine for allowing clients to get to DHCP; however, I've added another server address to the dhcp-relay profile, 10.10.80.13, which is a Mac server for netbooting and this does not work - clients don't see the Mac server as an available boot option.
The odd thing is that adding that server address to a specified VLAN in the network core on an HPE 5412Rzl2 switch using 'ip helper-address', it does work correctly. Just can't get it to work on S2500.
Any thoughts or ideas? Thanks.
