Campus Switching and Routing
is it recomended to use /23 or less for clients
I have 5000 clients and building of 7 floors, vendor recomended using a pool of /23 vlans to allow users roaming between the floors without dropingvthe connection.
#AirheadsMobile
Re: is it recomended to use /23 or less for clients
Yes you can go even bigger as long broadcast and multicast optimizations are enabled. Take a look at the single VLAN VRD.
Tim Cappalli | Aruba Security TME
Single VLAN Architecture VRD:  http://community.arubanetworks.com/t5/Validated-Reference-Design/Single-VLAN-Architecture-for-WLAN/ta-p/257196
Colin Joseph
Aruba Customer Engineering
Contributor I
Yes no problem, as long as match with you requirement.
AFK
Contributor I
We use /20 and /21 networks at our locations (with broadcast and multicast optimizations enabled on the controllers), and we have no problems with it.
