Campus Switching and Routing
Frequent Contributor I
lacp performance degradation
We are currently in the process of activating lacp profiles for our IAP-225's following the configuration provided by madjali in this post.
The issue we are seeing is after the third port channel, the MAS becomes unresponsive for a few seconds, after the fourth putty will time-out every time we add a port to the port-channels. After the fifth the MAS will stop responding to pings every 30 seconds or so and causing all connected devices to lose the network.
Is there there a step we missed during config? We have experienced this on more than one stack. We are running IAP v. and MAS
Super Contributor I
Re: lacp performance degradation
Total shot in the dark -- the first place I'd look is to see if the switch uplink is going through some sort of spanning tree state transition.
