Campus Switching and Routing
licensing when using HA fast failover
I recently migrated from VRRP to HA fast failover, Do i still need to configure centralized licensing in my controllers?
Re: licensing when using HA fast failover
Yes.
I changed the IP of the master controller to the virtual ip address that was used and its not letting me reconfigure centralized licensing
Whatever controller is the real master should allow you to configure centralized licensing.  If you type "show switchinfo" on the commandline of a controller, it should tell you its current role:
switchrole:master
Configuration Changed since last save
No crash information available.
Reboot Cause: User reboot (Intent:cause:register 78:86:0:2c)
(Aruba7640-US) #
