Campus Switching and Routing
modular backplane stacking
Hi:
I am learning Aruba OS-Switch  stacking technology.
I would like to ask a question about stacking technology,Some switches support VSF and modular backplane stacking,I know that when the switch uses VSF,need to do some configuration and how to configure it. My problem is when using modular backplane stacking. Which configuration do I need to make?
Re: modular backplane stacking
Hi!
Setting up a backplane stack is a fairly simple process.  You just need to power off all the switches in the stack, insert the stacking module and cables to the desired topology, and power on each switch, one at a time, in the order you want the stack members to come up in.
The first switch that you power on will become the commander of the stack.  The second one will become the standby.  After bringing up all the stack members, you can change which members you want to become commander and standby using the "stack priority" feature.
More details on stacking can be found in the installation and getting starting guide here (pg 47):
https://support.hpe.com/hpsc/doc/public/display?docId=c04948676
Stacking details can be found in the Advanced Traffic Management Guide here (pg 328):
https://support.hpe.com/hpsc/doc/public/display?docId=a00038722en_us
Justin
JUSTIN NOONAN
TECHNICAL MARKETING ENGINEER – ARUBA WIRED INTELLIGENT EDGE
O: +1 916 540 1748   |   justin.noonan@hpe.com
8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747 USA
