Campus Switching and Routing
Occasional Contributor I
stacking interface add stk
Hope someone can help.........please.....................
We are trying to stack an Aruba S3500 and a S2500 without traditional stacking fiber cables. We would like to lag or ether channel 2 ports to the switches. DOes anyone have commands to do this. I have tried to re-search it all day and can't find anything without using the fiber cables in the slots......
We are trying to use ports 1 and 2 for the channel between switches.
Can someone help me please......................
Wall
Aruba
Re: stacking interface add stk
[ Edited ]
Wally,
Ports 22/23 and 46/47 are the QA qualified base stack ports for the S2500s and S3500-24P/T or 48P/T. The command to enable stacking on those ports is as follows:
(host) # add stacking interface stack <module/port>
So to enable port 46 or 47 it would be as follows:
add stacking interface stack 0/46
or
add stacking interface stack 0/47
It can be done from config mode or executive mode since they modify the stacking database and not the startup/running config.
The user-guide has these commands as well as the validated topologies.
http://www.arubanetworks.com/techdocs/ArubaOS_73_Web_Help/Default.htm#mas_guides/aruba_stack/Stacking.htm%3FTocPath%3DArubaStack%7C_____0
Best regards,
Madani
Thanks so much......The document alone was a huge help...........
Wally
