Campus Switching and Routing
upgrade firmware to a 5400 with dual managment module
What is the procedure to upgrade a 5406Rzl2?
i bealive i have to upload and update like a normally do witth swtiches, but there must be  a step in which i transfer the new firrmware to the secondary managment module!
Anyone can guide me with this plz?
Cheers
Carlos
Alternetworks Corp
Contributor I
Re: upgrade firmware to a 5400 with dual managment module
This is done automatically by the switch. If you do a "copy .."  command the flash of the two mgmt modules are synced in the background.
