Campus Switching and Routing
Occasional Contributor I
upgraded MAS s2500 from 7.3 to 7.4.0.1 and some interfaces lost vlans
config before upgrade
interface-group gigabitethernet "vlan204"
apply-to 0/0/30-0/0/47,0/1/1-1/0/11
mstp-profile "PortFast"
poe-profile "poe-factory-initial"
aaa-profile "default"
switching-profile "vlan204"
config after upgrade
Contributor II
Re: upgraded MAS s2500 from 7.3 to 7.4.0.1 and some interfaces lost vlans
The config you supplied seems to have 'typo'
because when I tried the exact config:
(MAS) (config) #interface-profile switching-profile "vlan204"
(MAS) (gigabitethernet "vlan204") #apply-to 0/0/30-0/0/47,0/1/1-1/0/11
Invalid value
i.e,
The last interface ID 1/0/11 --> this is invalid, I suppose you mean 1/0/1 ?
Assuming that, I tried below config on 7.3.0.0 (build-40599)
Then, upgraded to 7.4.0.1 (build-47484).
 ==> Post upgrade, I don't see the issue.
        Meaning: same above configuration remained intact
Rgds,
-Vinay
Contributor II
Rectifying a small copy paste error of mine in above:
(MAS) (config) #interface-group gigabitethernet "vlan204"
Invalid value
With proper ports specified issue is not seen.
Not a typo.  pasted from tfpt copy of run cfg of MAS.
I fixed by changing 0/1/1 to 1/0/0
does 7.4.0.1 process interface ranges differently?
Thanks for reply
Chewbacca-jhh,
Please open a case with TAC, so that they can replicate with your config.
case #1653750
