Campus Switching and Routing
Occasional Contributor I
what is the max no. of hosts can be assigned from built in dhcp server in mobility access switch
what is the max no. of hosts and DHCP pools can be assigned from built in dhcp server in mobility access switch?
Valued Contributor II
Re: what is the max no. of hosts can be assigned from built in dhcp server in mobility access switch
HI,
Indeed, there is no limit of scope entries, but we can configure only 6 profile entries. and there are some limitation for creating VPN pools.
Please feel free for any further clarity on this.
Cheers,
Venu Puduchery,
