Campus Switching and Routing
Occasional Contributor I
where to get updated os files for aruba 3810m switch
Seems like the re-design of the HPE support center,  I am 100% unable to find the updated OS files for the Aruba 3810 series switches.  Can someone point me in the right direction?
Re: where to get updated os files for aruba 3810m switch
This is correct. In order to make it easy for you I've added link to firmware:
https://h10145.www1.hpe.com/downloads/SoftwareReleases.aspx?ProductNumber=JL074A
Greetings!
Another option that remains available is the My Networking Support Lookup tool, which allows you to search by product family and provides links directly to the appropriate software download page.
Matthew Fern | Technical Marketing Engineer, Wired Intelligent Edge
Aruba, a Hewlett Packard Enterprise Company
I went looking about a month ago.  Even though the product would show up,  it was telling me no downloads were available.  They are there now though.
