Cloud Managed Networks
Bandwidth consumption for communication between AP and Central
Helllo,
Can anyone tell me how much bandwidth (MB) is consumed through the connection between the AP and the Central. I understand should be very little since the communication is for report or occasionally provisioning.
Also, the communication occurs between each AP in a cluster with the Aruba Central? Or only the Master AP in an instant cluster communicates with Central ?
Re: Bandwidth consumption for communication between AP and Central
It is the master IAP in the cluster which communicates with Central.
However, in some cases eg apprf data, the communication can take place between slave & Central as well.
Thanks for the info. Do you know what is the average bandwidth for reporting between the Master IAP to Aruba Central?
