Community Feedback
Contributor I
Feature request for Aruba Products
I don't see any option to provide feedback to Aruba, like submit a feature request or a request for enhancements.
Older topics do mention an option within the aruba support portal, but since the the support merged with HPE this isn't actual anymore.
Is there any option to provide such feedback?
Aruba ACCX #748, ACDX #758, ACMP, ACEAP | HPE Master ASE
Re: Feature request for Aruba Products
Fabian,
If you have access to the Aruba Partner portal, there is the Ideas section that is still operational. However, for the best results and until we have a new RFE/Feature Request portal across all the Aruba products, for best results, I would advise you to place your FR/RFE through your local Aruba SE or CSE. They can also search the system for possible duplicates which may save you a lot of time describing your request.
Herman
