Community Feedback
issues with SSO and logging into Airheads
not sure who is having issues like mine...
I can't log into Airheads now for a week or two.
I click on sign in asks me for my username/pass
I click connect or whatever it is
it redirects and it hangs...
if I sign into the support site i don't have an issue.
I am also usually able to sign into the support site head over to Airheads then click on sign in and the SSO will take over and log me in but it doesn't
ff version 38.0.5
checked with a colleague and they have the same issue.
chrome as well....
not sure how to fix this...
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
MVP
Re: issues with SSO and logging into Airheads
Is this about the App or Web Version?
Sean Rynearson
web I can only post through the app. sorry should have specified.
ACDX #420 | ACCA
Regular Contributor I
I had this issue a few weeks ago and even TAC were unable to help - I just had to have a new account created.
MVP
Let me open a lithium support ticket.
Sean Rynearson
resolved itself and i have not had the problem since. Thanks Sean for opening a ticket for me
ACDX #420 | ACCA
