Community Tribal Knowledge Base
A network management approach for wired and wireless hybrid networks
Entuity
New Member
I've attached an article that explains how regular multi-vendor wired networks that also include Aruba wireless components can be managed together using the same Network Management suite. This focuses on the use of the Eye of the Storm (EYE) package from Entuity and highlights the fact that Aruba wireless controller based networks are a standard supported feature.
Version history
Revision #:
3 of 3
Last update:
‎08-13-2013 12:11 PM
Updated by:
Labels (2)
Contributors
