Community Tribal Knowledge Base
Aruba AirMesh MSR2000 Outdoor Wireless Mesh Router Password Recovery
Retired Employee alc
Retired Employee
Question
I have an MSR 2000 that I cannot access past the login screen because I don't know the password. Is there a way to default the MSR back to factory settings without logging into it?
Answer
Yes.
Per the user guide, there is a factory reset procedure intended for devices that are up on poles and not easily reached.
You hard cycle the power 6 times - waiting for the device to fully boot each time (as indicated by the status lights).
On the 7th cycle the unit should boot up with a factory default configuration.
You can also open a TAC case and a TAC engineer can help get you in if there is remote access to the device.
Version history
Revision #:
1 of 1
Last update:
‎06-19-2013 11:59 AM
Updated by:
