Configuring OpenDNS on Aruba Mobility Controller
OpenDNS
New Member
  • OpenDNS can be used across a wide variety of networks. Since DNS is a common layer shared by any type of network, configuration is simple no matter the complexity of your network topology. The attached guide focuses on configuring your VLAN's DHCP settings in Aruba Campus WLAN OS version 6.0.1.x to point to the OpenDNS IPs (209.67.222.222, 208.67.220.220)
  • If you're using an internal DNS server let us know what you're using (BIND, Windows Server, etc.) and we'll put together instructions that are more specific to your deployment.
  • For more information, please visit www.opendns.com
Version history
Revision #:
6 of 6
Last update:
‎08-12-2013 08:52 AM
Updated by:
Labels (2)
Contributors
