802.11r configuration on Aruba Controller
Certain wireless deployments such as VoWiFi are very sensitive to loss of connectivity while client roams between APs. 802.11r / Fast BSS Transition (FT) is the IEEE amendment   which focuses on reducing the time period for which client loses connectivity.
FT operates on below principles :
  • Authenticate client only when it initially enters the mobility domain (i.e. 802.11r mobility domain) by connecting to an AP
  • Do only key exchange when client roams to a new AP
  • The key exchange to new AP can happen
  1. Over-the-Air :: Overloading key information with 802.11 auth & reassociation management frames which is part of any client roam event.
  2. Over-the-DS :: Communicating to new AP thru the connected AP via wired infrastructure.
As of ArubaOS 6.3; below are the limitations of 802.11r feature in ArubaOS :
  • Only Over-the-Air FT is supported
  • FT roaming is only supported betweens APs in same 802.11r mobility domain within same controller i.e. inter-controller roaming isn't supported
  • FT roaming isn't supported in split-tunnel forward mode
Environment: Any Aruba Campus or Remote AP deployment running ArubaOS 6.3.0.0 or above.
Network Topology: Any campus or remote AP deployment with roaming client.
Creation of 11r Profile ::
(Aruba-Master) (config) #wlan dot11r-profile voice
(Aruba-Master) (802.11r Profile "voice") #dot11r
(Aruba-Master) (802.11r Profile "voice") #exit
(Aruba-Master) (config) #show wlan dot11r-profile voice
Mapping to SSID Profile ::
(Aruba-Master) (config) #wlan ssid-profile voice dot11r-profile voice
(Aruba-Master) (config) #write memory
Configuration Validation ::
Parameter                     Value
Advertise 802.11r Capability  Enabled
802.11r Mobility Domain ID    1
802.11r R1 Key Duration       3600
802.11r R1 Key Assignment     dynamic
(Aruba-Master) (config) #show wlan ssid-profile voice
SSID Profile "voice"
Parameter                                         Value
SSID enable                                       Enabled
ESSID                                             voice
Encryption                                        wpa2-aes
DTIM Interval                                     2 beacon periods
802.11a Basic Rates                               12 18 24 36 48 54
802.11a Transmit Rates                            12 18 24 36 48 54
802.11g Basic Rates                               11 12 18 24 36 48 54
802.11g Transmit Rates                            11 12 18 24 36 48 54
Station Ageout Time                               1000 sec
Max Transmit Attempts                             8
RTS Threshold                                     2333 bytes
Short Preamble                                    Enabled
Max Associations                                  64
Wireless Multimedia (WMM)                         Enabled
Wireless Multimedia U-APSD (WMM-UAPSD) Powersave  Enabled
WMM TSPEC Min Inactivity Interval                 0 msec
Override DSCP mappings for WMM clients            Disabled
DSCP mapping for WMM voice AC                     46
DSCP mapping for WMM video AC                     N/A
DSCP mapping for WMM best-effort AC               N/A
DSCP mapping for WMM background AC                N/A
Multiple Tx Replay Counters                       Disabled
Hide SSID                                         Disabled
Deny_Broadcast Probes                             Disabled
Local Probe Request Threshold (dB)                20
Disable Probe Retry                               Enabled
Battery Boost                                     Disabled
WEP Key 1                                         N/A
WEP Key 2                                         N/A
WEP Key 3                                         N/A
WEP Key 4                                         N/A
WEP Transmit Key Index                            1
WPA Hexkey                                        N/A
WPA Passphrase                                    ********
Maximum Transmit Failures                         30
EDCA Parameters Station profile                   N/A
EDCA Parameters AP profile                        N/A
BC/MC Rate Optimization                           Enabled
Rate Optimization for delivering EAPOL frames     Enabled
Strict Spectralink Voice Protocol (SVP)           Disabled
High-throughput SSID Profile                      HT-On
802.11g Beacon Rate                               12
802.11a Beacon Rate                               18
Advertise QBSS Load IE                            Disabled
Advertise Location Info                           Disabled
Advertise AP Name                                 Disabled
802.11r Profile                                   voice
Enforce user vlan for open stations               Disabled
Working Validation :
auth-tracebuf command can be used to validate that the client isn't doing complete 802.1x (or just key exchange as in OKC) while roaming between APs.
(Aruba-Local) #         show auth-tracebuf mac 48:74:6e:d1:29:0f
Warning: user-debug is enabled on one or more specific MAC addresses;
      only those MAC addresses appear in the trace buffer.
Auth Trace Buffer
Jun 25 08:29:17  station-up             *  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             -    -     wpa2 aes
Jun 25 08:29:17  eap-id-req            <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             1    5
Jun 25 08:29:17  eap-id-resp           ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             1    19    Voice_Pilot
Jun 25 08:29:17  rad-req               ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             193  219
Jun 25 08:29:17  rad-resp              <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  193  90
Jun 25 08:29:17  eap-req               <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             2    6
Jun 25 08:29:17  eap-resp              ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             2    152
Jun 25 08:29:17  rad-req               ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  202  390
Jun 25 08:29:17  rad-resp              <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  202  1188     <-- Complete Authentication happen once
Jun 25 08:29:17  eap-req               <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             3    1096
Jun 25 08:29:17  eap-resp              ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             3    6
Jun 25 08:29:17  rad-req               ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  115  244
Jun 25 08:29:17  rad-resp              <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  115  1188
Jun 25 08:29:17  eap-req               <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             4    1096
Jun 25 08:29:17  eap-resp              ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             4    6
Jun 25 08:29:17  rad-req               ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  97   244
Jun 25 08:29:17  rad-resp              <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  97   712
Jun 25 08:29:17  eap-req               <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             5    624
Jun 25 08:29:19  eap-resp              ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             5    348
Jun 25 08:29:19  rad-req               ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  237  588
Jun 25 08:29:19  rad-resp              <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  237  153
Jun 25 08:29:19  eap-req               <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             6    69
Jun 25 08:29:19  eap-resp              ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             6    6
Jun 25 08:29:19  rad-req               ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  249  244
Jun 25 08:29:19  rad-resp              <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  249  127
Jun 25 08:29:19  eap-req               <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             7    43
Jun 25 08:29:19  eap-resp              ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             7    59
Jun 25 08:29:19  rad-req               ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  137  297
Jun 25 08:29:19  rad-resp              <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  137  143
Jun 25 08:29:19  eap-req               <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             8    59
Jun 25 08:29:19  eap-resp              ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             8    59
Jun 25 08:29:19  rad-req               ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  211  297
Jun 25 08:29:19  rad-resp              <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  211  159
Jun 25 08:29:19  eap-req               <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             9    75
Jun 25 08:29:19  eap-resp              ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             9    107
Jun 25 08:29:19  rad-req               ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  73   345
Jun 25 08:29:19  rad-resp              <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  73   175
Jun 25 08:29:19  eap-req               <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             10   91
Jun 25 08:29:19  eap-resp              ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             10   43
Jun 25 08:29:19  rad-req               ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  86   281
Jun 25 08:29:19  rad-resp              <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  86   191
Jun 25 08:29:19  eap-req               <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             12   107
Jun 25 08:29:19  eap-resp              ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             12   43
Jun 25 08:29:19  rad-req               ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  199  281
Jun 25 08:29:19  rad-accept            <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43/PTP-Radius  199  330
Jun 25 08:29:19  eap-success           <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             12   4
Jun 25 08:29:19  wpa2-key1             <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             -    117
Jun 25 08:29:19  wpa2-key2             ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             -    240
Jun 25 08:29:19  wpa2-key3             <-  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             -    279
Jun 25 08:29:19  wpa2-key4             ->  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             -    95
Jun 25 08:30:13  station-down           *  48:74:6e:d1:29:0f  9c:1c:12:b3:49:43             -    -
Jun 25 08:30:13  station-up             *  48:74:6e:d1:29:0f  9c:1c:12:b1:a6:63             -    -     wpa2 aes
Jun 25 08:30:21  station-down           *  48:74:6e:d1:29:0f  9c:1c:12:b1:a6:63             -    -
Jun 25 08:30:21  station-up             *  48:74:6e:d1:29:0f  9c:1c:12:b1:ab:23             -    -     wpa2 aes
Jun 25 08:30:38  station-down           *  48:74:6e:d1:29:0f  9c:1c:12:b1:ab:23             -    -
Jun 25 08:30:38  station-up             *  48:74:6e:d1:29:0f  9c:1c:12:b3:60:23             -    -     wpa2 aes
Jun 25 08:30:47  station-down           *  48:74:6e:d1:29:0f  9c:1c:12:b3:60:23             -    -
Jun 25 08:30:47  station-up             *  48:74:6e:d1:29:0f  9c:1c:12:b3:4b:e3             -    -     wpa2 aes
Jun 25 08:30:55  station-down           *  48:74:6e:d1:29:0f  9c:1c:12:b3:4b:e3             -    -
Jun 25 08:30:55  station-up             *  48:74:6e:d1:29:0f  9c:1c:12:b1:b0:03             -    -     wpa2 aes
Jun 25 08:31:08  station-down           *  48:74:6e:d1:29:0f  9c:1c:12:b1:b0:03             -    -
Jun 25 08:31:08  station-up             *  48:74:6e:d1:29:0f  9c:1c:12:b1:a6:43             -    -     wpa2 aes
Jun 25 08:31:30  station-down           *  48:74:6e:d1:29:0f  9c:1c:12:b1:a6:43             -    -
Jun 25 08:31:30  station-up             *  48:74:6e:d1:29:0f  9c:1c:12:b3:60:03             -    -     wpa2 aes
Jun 25 08:31:44  station-down           *  48:74:6e:d1:29:0f  9c:1c:12:b3:60:03             -    -
Jun 25 08:31:44  station-up             *  48:74:6e:d1:29:0f  9c:1c:12:b1:af:03             -    -     wpa2 aes     <-- 802.11r in action.
Jun 25 08:32:00  station-down           *  48:74:6e:d1:29:0f  9c:1c:12:b1:af:03             -    -
Jun 25 08:32:00  station-up             *  48:74:6e:d1:29:0f  9c:1c:12:b3:60:03             -    -     wpa2 aes
Jun 25 08:32:16  station-down           *  48:74:6e:d1:29:0f  9c:1c:12:b3:60:03             -    -
Jun 25 08:32:16  station-up             *  48:74:6e:d1:29:0f  9c:1c:12:b1:a6:43             -    -     wpa2 aes
Jun 25 08:32:25  station-down           *  48:74:6e:d1:29:0f  9c:1c:12:b1:a6:43             -    -
Jun 25 08:32:25  station-up             *  48:74:6e:d1:29:0f  9c:1c:12:b1:8e:43             -    -     wpa2 aes
Jun 25 08:32:43  station-down           *  48:74:6e:d1:29:0f  9c:1c:12:b1:8e:43             -    -
Jun 25 08:32:43  station-up             *  48:74:6e:d1:29:0f  9c:1c:12:b1:a6:c3             -    -     wpa2 aes
Jun 25 08:32:52  station-down           *  48:74:6e:d1:29:0f  9c:1c:12:b1:a6:c3             -    -
Jun 25 08:32:52  station-up             *  48:74:6e:d1:29:0f  9c:1c:12:b1:aa:c3             -    -     wpa2 aes
Validate whether AP has "r" flag i.e. SSID with 11r is mapped to right AP-Group.
show ap active
Active AP Table
Name                    Group            IP Address       11g Clients  11g Ch/EIRP/MaxEIRP  11a Clients  11a Ch/EIRP/MaxEIRP   AP Type  Flags  Uptime           Outer IP
1-3-1152A             Test-AP-Group     192.168.99.203   1            AP:HT:1/12/21.5      0            AP:HT:48-/12/22       135      Aar    40d:11h:36m:41s  N/A
1-4-1101A             Test-AP-Group     192.168.98.86    2            AP:HT:1/12/21.5      0            AP:HT:48-/21.5/22     135      Aar    7d:17h:58m:13s   N/A
1-3-1169A             Test-AP-Group     192.168.98.14    3            AP:HT:1/12/21.5      0            AP:HT:48-/21.5/22     135      Aar    40d:11h:36m:56s  N/A
1-3-1155A             Test-AP-Group     192.168.99.106   3            AP:HT:1/12/21.5      0            AP:HT:157+/12/22.5    135      Aar    45d:21h:24m:43s  N/A
1-3-1172A             Test-AP-Group     192.168.98.175   2            AP:HT:1/12/21.5      1            AP:HT:149+/12/22.5    135      Aar    40d:11h:36m:53s  N/A
1-5-1056A             Test-AP-Group     192.168.98.107   1            AP:HT:11/12/21.5     0            AP:HT:157+/22.5/22.5  135      Aar    38d:21h:35m:47s  N/A
1-3-1148A             Test-AP-Group     192.168.99.109   0            AP:HT:11/12/21.5     1            AP:HT:44+/21.5/22     135      Aar    40d:11h:36m:34s  N/A
Flags: 1 = 802.1x authenticated AP; 2 = Using IKE version 2;
       A = Enet1 in active/standby mode;  B = Battery Boost On; C = Cellular;
       D = Disconn. Extra Calls On; E = Wired AP enabled; F = AP failed 802.1x authentication;
       H = Hotspot Enabled; K = 802.11K Enabled; L = Client Balancing Enabled; M = Mesh;
       N = 802.11b protection disabled; P = PPPOE; R = Remote AP;
       S = AP connected as standby; X = Maintenance Mode;
       a = Reduce ARP packets in the air; d = Drop Mcast/Bcast On; u = Custom-Cert RAP;
       r = 802.11r Enabled
CAC Flags: H = Handover Resv. Threshold Reached; P = Peak Cap. Reached
Validate if the client is 11r capable.
show ap association
Association Table
Name                bssid              mac            auth  assoc  aid  l-int  essid       vlan-id  tunnel-id  phy             assoc. time    num assoc  Flags  Band steer moves (T/S)
CUP-3-1159A        9c:1c:12:b3:60:03  48:74:6e:dd:27:c8  y     y      1    20     voice       2160     0x1028f    g-HT-20-1ss     8m:18s       1          WRA    0/0
CUP-3-1159A        9c:1c:12:b3:60:03  00:88:65:72:3c:2c  y     y      2    20     voice       2160     0x1028f    g-HT-20sgi-1ss  16s          2          WRAB   22/18
CUP-3-1163A        9c:1c:12:b1:a6:d3  94:94:26:95:5d:38  y     y      1    20     voice       2160     0x105cc    a-HT-40sgi-1ss  9m:1s        2          WRAB   3/3
CUP-3-1163A        9c:1c:12:b1:a6:c3  48:74:6e:d2:13:69  y     y      2    20     voice       2160     0x109dc    g-HT-20-1ss     1m:44s       1          WRA    0/0
The phy column shows client's operational capabilities for current association
Flags: A: Active, B: Band Steerable, H: Hotspot(802.11u) client, K: 802.11K client, R: 802.11R client, W: WMM client, w: 802.11w client
PHY Details: HT   : High throughput;      20: 20MHz;  40: 40MHz
             VHT  : Very High throughput; 80: 80MHz; 160: 160MHz; 80p80: 80MHz + 80MHz
             <n>ss: <n> spatial streams
Validate if client is sending MDIE & PMKID by enabling user-debug.
Jun 25 08:33:40  stm[3471]: <501095> <NOTI> |stm|  Assoc request @ 08:33:40.166921: 48:74:6e:d0:56:9d (SN 2774): AP 192.168.99.77-9c:1c:12:b1:aa:c3-TestAP1
Jun 25 08:33:40  authmgr[3470]: <522036> <INFO> |authmgr|  MAC=48:74:6e:d0:56:9d Station DN: BSSID=9c:1c:12:b1:a6:c3 ESSID=voice VLAN=2160 AP-name=CUP-3-1163A
Jun 25 08:33:40  authmgr[3470]: <522234> <DBUG> |authmgr|  Setting idle timer for user 48:74:6e:d0:56:9d to 300 seconds (idle timeout: 300 ageout: 0).
Jun 25 08:33:40  authmgr[3470]: <522152> <DBUG> |authmgr|  station free: bssid=9c:1c:12:b1:a6:c3, @=0x0x11345cc.
Jun 25 08:33:40  stm[3471]: <501080> <NOTI> |stm|  Deauth to sta: 48:74:6e:d0:56:9d: Ageout AP 192.168.98.167-9c:1c:12:b1:a6:c3-CUP-3-1163A STA has roamed to another AP
Jun 25 08:33:40  stm[3471]: <501100> <NOTI> |stm|  Assoc success @ 08:33:40.167728: 48:74:6e:d0:56:9d: AP 192.168.99.77-9c:1c:12:b1:aa:c3-TestAP1
Jun 25 08:33:40  authmgr[3470]: <522035> <INFO> |authmgr|  MAC=48:74:6e:d0:56:9d Station UP: BSSID=9c:1c:12:b1:aa:c3 ESSID=voice VLAN=2160 AP-name=TestAP1
Jun 25 08:33:40  authmgr[3470]: <522077> <DBUG> |authmgr|  MAC=48:74:6e:d0:56:9d ingress 0x0x10353 (tunnel 851), u_encr 64, m_encr 64, slotport 0x0x2100 , type: local, FW mode: 0, AP IP: 0.0.0.0 mdie 1 ft_complete 0
Jun 25 08:33:40  authmgr[3470]: <522078> <DBUG> |authmgr|  MAC=48:74:6e:d0:56:9d, wired: 0, vlan:2160 ingress:0x0x10353 (tunnel 851), ingress:0x0x10353 new_aaa_prof: voice, stored profile: voice stored wired: 0 stored essid: voice, stored-ingress: 0x0x1053d
Jun 25 08:33:40  authmgr[3470]: <522247> <DBUG> |authmgr|  User idle timer removed for user with  MAC 48:74:6e:d0:56:9d.
Jun 25 08:33:40  authmgr[3470]: <522258> <DBUG> |authmgr|  "VDR - Add to history of user user 48:74:6e:d0:56:9d vlan 0 derivation_type Reset VLANs for Station up index 15.
Jun 25 08:33:40  authmgr[3470]: <522255> <DBUG> |authmgr|  "VDR - set vlan in user for 48:74:6e:d0:56:9d vlan 2160 fwdmode 0 derivation_type Default VLAN.
Jun 25 08:33:40  authmgr[3470]: <522258> <DBUG> |authmgr|  "VDR - Add to history of user user 48:74:6e:d0:56:9d vlan 2160 derivation_type Default VLAN index 16.
Jun 25 08:33:40  authmgr[3470]: <522255> <DBUG> |authmgr|  "VDR - set vlan in user for 48:74:6e:d0:56:9d vlan 2160 fwdmode 0 derivation_type Current VLAN updated.
Jun 25 08:33:40  authmgr[3470]: <522258> <DBUG> |authmgr|  "VDR - Add to history of user user 48:74:6e:d0:56:9d vlan 2160 derivation_type Current VLAN updated index 17.
Jun 25 08:33:40  authmgr[3470]: <522246> <DBUG> |authmgr|  Idle timeout should be driven by STM for MAC 48:74:6e:d0:56:9d.
Jun 25 08:33:40  authmgr[3470]: <522254> <DBUG> |authmgr|  VDR - mac 48:74:6e:d0:56:9d rolename logon fwdmode 0 derivation_type Initial Role Contained vp not present.
Jun 25 08:33:40  authmgr[3470]: <522258> <DBUG> |authmgr|  "VDR - Add to history of user user 48:74:6e:d0:56:9d vlan 0 derivation_type Reset Role Based VLANs index 18.
Jun 25 08:33:40  authmgr[3470]: <522083> <DBUG> |authmgr|  Skip User-Derivation, mba:0 udr_exist:0,default_role:logon,pDefRole:0x0xeb1c44
Jun 25 08:33:40  authmgr[3470]: <524124> <DBUG> |authmgr|  dot1x_supplicant_up(): MAC:48:74:6e:d0:56:9d, pmkid_present:True, pmkid:bf 11 bd c6 d8 11 0b aa 74 10 1d 71 0e 6d ad 48
Jun 25 08:33:40  authmgr[3470]: <522243> <DBUG> |authmgr|  MAC=48:74:6e:d0:56:9d Station Updated Update MMS: BSSID=9c:1c:12:b1:aa:c3 ESSID=voice VLAN=2160 AP-name=TestAP1
Jun 25 08:33:40  authmgr[3470]: <522077> <DBUG> |authmgr|  MAC=48:74:6e:d0:56:9d ingress 0x0x10353 (tunnel 851), u_encr 64, m_encr 64, slotport 0x0x2100 , type: local, FW mode: 0, AP IP: 0.0.0.0 mdie 1 ft_complete 1
In addition to logging; Over The Air capture can be collected to validate client / AP packet transactions.
In case of Bridge / Decrypt-Tunnel; AP is the holder of R1 key. To validate if the AP has R1 key; below command can be used.
(Aruba3600) #show ap debug dot11r state ap-name TestAP
Stored R1 Keys
Station MAC        Mobility Domain ID  Validity Duration  R1 Key
48:74:6e:d0:56:9d  1                   3492               (32): 49 ae d2 8f 96 8f e8 ba 3d c6 f5 fa 15 ea a9 fd d3 82 5e 86 ab 09 34 2d 3d 62 3c b5 79 22 f5 af
To remove the key for a client; we can use the command
(Aruba3600) #ap debug dot11r remove-key 48:74:6e:d0:56:9d ap-name TestAP
Stored R1 Keys
The command "show ap debug dot11r efficiency" can be used to check hit / miss % of R1 key.
(UPHS-HUP-Local-PMC) #show ap debug dot11r efficiency
Fast Roaming R1 Key Efficiency
Client MAC         Hit (%)  Miss (%)
48:74:6e:d0:56:9d  0 (0%)   0 (0%)
Version history
Revision #:
2 of 2
Last update:
‎08-06-2014 01:58 PM
Updated by:
Contributors
Tags (1)
