AMON Enhancement introduced in 6.4.4.8
MVP
MVP
Q:
How to configure AMON packet size in Aruba Controller?
A:
When upgrading from an existing ArubaOS 6.4.4.x release, it is required to set the AMON packet size manually to a desired value.
However, the packet size is increased to 32K by default for fresh installations of ArubaOS 6.4.4.8.
(Master-7210) (config) #amon msg-buffer-size <msg-buffer-size>
<msg-buffer-size>       size in bytes. 1280-40960 bytes allowed
Version history
Revision #:
2 of 2
Last update:
‎07-19-2016 02:17 PM
Updated by:
Labels (1)
Contributors
