AP-214/215 or IAP-214/215 USB port functionality with POE / POE+ capable switch
MVP
MVP
Q:
Does AP-214/215 or IAP-214/215 enable USB port with POE / POE+ capable switch?
A:
AP-214/215 or IAP-214/215 treats both POE and POE+ power source as POE.
This is a hardware limitation with this model of AP and the USB port will be disabled and its the expected behaviour.
The USB port will be enabled only with the power adapter.
Version history
Revision #:
2 of 2
Last update:
‎07-25-2016 12:50 PM
Updated by:
Contributors
