AP capacity for 600 series controller
Product & Software: This applies to 600 series controller running AOS 6.2 and above.
AP capacity for 600 series controller has been revised in AOS 6.2 and this limit has been to restored from and above.
Starting with ArubaOS, controllers support the following number of APs. Consider the following limits when upgrading to ArubaOS 6.2 or later:
Version history
Revision #:
1 of 1
Last update:
‎07-01-2014 05:37 PM
Updated by:
Labels (1)
