AppRF and WebCC and IP NAT Inside
MVP
MVP
Q:
Could "IP NAT Inside" co-exist with AppRF/DPI or WebCC?
A:
If the user subnet is private or non-routable and therefore needs to be source NAT'ed, the 'ip nat inside' option under the user VLAN could be enabled and will coexist with AppRF and WebCC policies.
Version history
Revision #:
2 of 2
Last update:
‎04-28-2015 03:03 PM
Updated by:
Labels (1)
Contributors
Tags (1)
