AppRF with Wifi-calling
MVP
MVP
Q:
Integration of Wifi-calling with AppRF?
A:
A new appid will be added to support wifi-calling called “alg-wifi-calling”. At the call start event handler in UCM process after the call has been identified as a wifi-calling call, the new wifi-calling appid will be programmed to the datapath session.
The wifi-calling app alg will be permitted in the user-role.
Upon identification of the service, post classification rules may be used to re-adjust the TOS if the admin chooses to do so.
Version history
Revision #:
2 of 2
Last update:
‎07-25-2016 01:09 PM
Updated by:
Labels (1)
Contributors
