Aps are not coming up on the Local controller when centralized licensing is enabled on the controller.
Environment Information :
Main Master-Local with multiple Master-Local setup and there is no license installed on the Local controllers.
Main Master (Licensing server: 172.30.3.199)  ===> WAN  ====> Master - Local
Main Local                                                       |
        WAN  ====> Master – Local
Aps terminating on the Local controller would need to consume a license from the Main Master to come up.
Main Local                                                       |
        WAN  ====> Master - Local (Aps terminating on this Local controller)
Main Licensing Server
(Main-1) #show license debug
Summary of licensing state
Centralized Licensing: Enabled
Switch Role: Master
License Role: License Server
Master IP: 0.0.0.0
Switch IP: 172.30.3.199
License Server IP: 0.0.0.0
(Main-1) #show license heartbeat stats
License Heartbeat Table
Client IP Address  HB Req      HB Resp     Total Missed  Last Update (secs. ago)
172.29.254.6       80419       80419       0             9
172.16.100.10      142089      142088      1             794102
172.30.4.5         161257      161257      0             8
172.30.3.200       185975      185975      0             5
172.30.8.5         185970      185969      1             19
159.116.164.5      57950       57950       0             5
172.29.250.8       185967      185966      1             29
159.116.165.5      22766       22766       0             22
172.30.3.199       185972      185972      0             2
159.116.167.165    185987      185986      1             10
172.29.252.5       81130       81130       0             25
Local Master
(Local-Master-1) #show switches
All Switches
IP Address     Name       Location              Type    Model      Version         Status  Configuration State  Config Sync Time (sec)  Config ID
159.116.165.5  FCH7210-1  Fostoria Data Center  master  Aruba7210  6.3.1.10_45532  up      UPDATE SUCCESSFUL    0                       9
159.116.165.6  FCH7210-2  Fostoria Data Center  local   Aruba7210  6.3.1.10_45532  up      UPDATE SUCCESSFUL    10                      9
(Local-Master-1) #show license client-table
Built-in limit: 0
License Client Table
Service Type                                        System Limit  Server Lic.  Used Lic.  Contributed Lic.  Remaining Lic.
Access Points                                       512           146          2          0                 146
Next Generation Policy Enforcement Firewall Module  512           146          2          0                 146
RF Protect                                          512           146          2          0                 146
xSec Module                                         4096          0            0          0                 0
Advanced Cryptography                               4096          0            0          0                 0
(Local-Master-1) #show license debug
Switch Role: Master
License Role: License Client
Master IP: 0.0.0.0
Switch IP: 159.116.165.5
License Server IP: 172.30.3.199
Local Controller
(Local-2) #show license client-table
Built-in limit: 0
Access Points                                       512           0            0          0                 0
Next Generation Policy Enforcement Firewall Module  512           0            0          0                 0
RF Protect                                          512           0            0          0                 0
(FCH7210-2) #show license debug
Switch Role: Local
Master IP: 159.116.165.5
Switch IP: 159.116.165.6
License Server IP: 159.116.165.5
The remaining license on the Local controller shows as 0 hence the Aps are not coming up.
Local Controller
Built-in limit: 0
There other masters configured as license clients for the Main master controller.
Multiple masters-locals in one centralized licensing topology is not supported.
We only support master-local or multi-master topology.
A combined configuration of multiple masters and master-local is not supported.
Version history
Revision #:
1 of 1
Last update:
‎04-07-2015 01:28 PM
Updated by:
Labels (1)
Contributors
