Are there any issues with having WMM enabled with a remote AP in split tunnel mode?
Product and Software: This article applies to all Aruba controllers and ArubaOS 3.x.
When you configure a remote AP in the split tunnel mode, make sure the Wireless Multi Media option on the Advanced tab of the SSID profile is disabled. Otherwise an error message is displayed and the user is not allowed to configure the forward mode as "split tunnel".
For now, the users connected to the RAP with split tunnel would not been shown in the show user-table output.
However, in ArubaOS 5.0 and later, users in the split tunnel mode can be seen in the show user-table output.
Version history
Revision #:
1 of 1
Last update:
‎06-30-2014 05:51 PM
Updated by:
Labels (1)
Contributors
