Aruba controller becomes unreachable through the network after adding RAP whitelist.
Environment Information- This article applies to Aruba Controllers running any version of ArubaOS.
Symptoms- Identifying the problem in such cases would be as the major symptom would be the accessibility controller goes down. All the Remote-APs will keep on trying to form IPSec SA to the controller but the tunnel never gets established.
Below are the screenshots that show datapath route-cahce when its working and not working:
The continuous Ping running to controller IP, gets immediately timed out after adding the controller switch IP as remote IP in the whitelist entry:
Cause- Datapath route-cache getting corrupted would become the cause of the issue:
Resolution- Remove the whitelist entry for the RAP and reload the controller.
Answer- In order to get out of this situation, the added whitelist entry has to be removed and controller needs to be reload.
Version history
Revision #:
1 of 1
Last update:
‎04-02-2015 11:41 PM
Updated by:
Labels (2)
Contributors
