Auto Downgrade from 6.3 to prior codes is not supported
Issue If downgrade is done automatically from 6.3 to prior codes without restoring the config of prior codes, we may run into situation of Network down. One such instance is VLAN Pooling config. The syntax of config for VLAN pooling has been changed from prior codes to 6.3 and this has been explained in this article.
If downgrade is done automatically from 6.3 to prior codes without restoring the config of prior codes, we may run into situation of Network down. One such instance is VLAN Pooling config. If VLAN pool name is referred in Virtual APs, and after downgrade the AP would not broadcast the SSID as it will miss the VLAN config for the Virtual AP.
Auto downgrade is not supported.
In addition, there is a cli change also with respect to named-vlan.
This happens as the vlan pool keyword changed in 6.3. So the named vlans are disabled after downgrade.
Losing vlan pool config in downgrade is expected as we do not support auto downgrade.
We would need to back up the 6.2/or pre 6.3 config before upgrading to 6.3.
If downgrade is needed, we recommend using the saved config.
If you downgrade from 6.3 to any of the older 6.2.x or 6.1.x builds you will lose the vlan pool config as the command for creating vlan pools has changed.
Our policy for downgrades has always been to save a config from 6.1 or 6.2 and reference it while booting. We don’t encourage auto config changes while doing downgrades.
This is will be documeneted in the upgrade path guide.
6.2.1.2 config:
(Aruba3600) #show  vlan mapping
Vlan Mapping Table
VLAN Name  Pool Status  Assignment Type  VLAN IDs
test       Enabled      Hash             1-2,30
test1      Enabled      Even             1-2
test2      Enabled      Hash             1,30
After upgrade to 6.3:
Vlan Mapping Table
VLAN Name  Assignment Type  VLAN IDs
test       Hash             1-2,30
test1      Even             1-2
test2      Hash             1,30
Note : The pool keyword is removed in 6.3. It is recommended to use the old config file for downgrade.
Aruba Strongly recommends to back up the config/flashbackup before an upgrade.
Version history
Revision #:
1 of 1
Last update:
‎07-10-2014 04:12 PM
Labels (1)
Contributors
