Can we determine the speed and duplex of an AP on the Aruba controller or do we need Airwave for it?
Q:
Can we determine the speed and duplex of an APs interfaces on the Aruba controller or do we need Airwave for it?
A:
Yes. We can find the speed and duplex of an AP on the Aruba controller.
Please use the following command to view the speed and duplex of an AP
(Aruba7240) #show ap debug system-status ap-name <name-of-ap> | include " eth"
  0      eth0  UP    ACTIVE   0
  1      eth1  DOWN  STANDBY  0
on       1000          Full     eth0
on       Unknown       Unknown  eth1
(Aruba7240) #
Note: The above command applies for a single AP. If we need to see the speed and Duplex for all the APs on the controller at once then we need to use Airwave Server.
Version history
Revision #:
2 of 2
Last update:
‎06-17-2015 05:28 AM
Updated by:
Labels (1)
Contributors
