Q:
How can we change the IP address of MD via MM ?
A: We can change the IP address of MD via MM using the following steps:
All Switches
IP Address IPv6 Address Name Location Type Model Version Status Configuration State Config Sync Time (sec) Config ID
10.15.56.85 None ArubaMM Building1.floor1 master ArubaMM-VA 8.1.0.1_59688 up UPDATE SUCCESSFUL 0 13
10.15.56.86 None Standby Building1.floor1 standby Aruba7005 8.1.0.1_59688 up UPDATE SUCCESSFUL 10 13
10.15.56.22 None ArubaMC-VA Building1.floor1 MD Aruba7005 8.1.0.1_59688 up UPDATE SUCCESSFUL 10 13 -------->MD
(ArubaMM) [mynode] #change_config_node ArubaMC-VA-------->Navigating to MD for changing the IP
(ArubaMM) [00:0c:29:ee:1a:24] #configure terminal
Enter Configuration commands, one per line. End with CNTL/Z
(ArubaMM) [00:0c:29:ee:1a:24] (config) #interface vlan 1
(ArubaMM) [00:0c:29:ee:1a:24] (config-submode)#ip address 10.15.56.23 255.255.255.0
This configuration change requires a reboot. Do you want to continue[y/n]:y
Controller will be rebooted on write memory.
All Switches
10.15.56.23 None ArubaMC-VA Building1.floor1 MD Aruba7005 8.1.0.1_59688 up UPDATE SUCCESSFUL 10 13 ------->New IP for MD
