Client Match Load Balancing Algortihm
MVP
MVP
Q:
Client Match Load Balancing Algorithm
A:
•Algorithm runs every 2 minutes, on a per band basis.
•Steers clients from over-loaded to under-loaded radios.
Version history
Revision #:
2 of 2
Last update:
‎10-18-2016 04:42 PM
Updated by:
Contributors
