Environment : This article applies to Aruba Mobility Controllers running ArubaOS version 6.0 and Above.
Many settings are unique to a controller and therefore are not replicated from a master controller to a local controller. The following settings must be manually configured on a local controller
Time zone and daylight savings time settings
VPN pools for remote APs and other VPN clients.
Controller and IP interfaces.
IP routing and spanning-tree configurations
Remote AP whitelist and local-user database values
DHCP pools and reservations
NAT pools
SNMP, NTP, and syslog settings
Hostnames, DNS and SMTP servers
ACLs applied to ports
Certificates
RADIUS client details and RADIUS source interfaces
Stateful firewall settings
Customized captive portal pages and images, and the captive portal redirect address.
Note : By default, the local controllers forward the authentication requests for the RAP whitelist and the local user database to the master controller. Therefore, this data does not have to be manually replicated unless the default behavior has been altered. The user table is NOT synchronized, so if an AP fails over to a master from a local or vice versa, that AP will have to re-authenticate.
